Api session event editor functionoverride remove category
API Endpoint: editorfunctionoverride/remove_category.
API Endpoint name is Api session event editor functionoverride remove category.
Use this endpoint to Remove Category
| 0 | REQUIRED | (FUNCTION Integer ID) | Function | |
| 1 | REQUIRED | (Enumeration) | Category | AGRICULTURE, BRIDGE, EDUCATION, GARDEN, HEALTHCARE, INDUSTRY, INTERSECTION, LEISURE, LUXE, NATURE, NORMAL, OFFICES, OTHER, PARK, PAVED_AREA, ROAD, SENIOR, SHOPPING, SOCIAL, STUDENT or UNDERGROUND |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/remove_category/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SOCIAL" ]'JavaScript example POST:
body: '[ 1, "SOCIAL" ]'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/remove_category/", options)
