Api session event editor eventbundle remove event
Revision as of 11:23, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editoreventbundle/remove_event.
API Endpoint name is Api session event editor eventbundle remove event.
Use this endpoint to Remove Event
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle
1 REQUIRED (true, false) Boolean true or false
2 REQUIRED (Integer number) Integer
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true, 1 ]'
JavaScript example POST:
 body: '[ 1, false, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/remove_event/", options)
