Api session event editor building set slanting roof height
Revision as of 11:22, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorbuilding/set_slanting_roof_height.
API Endpoint name is Api session event editor building set slanting roof height.
Use this endpoint to Change Height of the Slanting Roof of a Building section
0 REQUIRED (BUILDING Integer ID) Building ID
1 REQUIRED (Integer number) Section ID
2 REQUIRED (Floating point number) Slanting roof height
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 62 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 95 ]'
JavaScript example POST:
 body: '[ 1, 1, 62 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/", options)
