Api session event editor building generate rotation angles
API Endpoint: editorbuilding/generate_rotation_angles.
API Endpoint name is Api session event editor building generate rotation angles.
Use this endpoint to Calculation a rotation angle for Building having the identifying attribute polygons, optionally only for specified Building.
| 0 | REQUIRED | (String) | Identifying attribute | |
| 1 | REQUIRED | (String) | Rotation attribute | |
| 2 | OPTIONAL | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Specific BuildingIDs only (optional) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Identifying attribute", "Rotation attribute", "" ]'JavaScript example POST:
body: '[ "Identifying attribute", "Rotation attribute", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/", options)
