Api session event editor attributeaction remove
Revision as of 11:22, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorattributeaction/remove.
API Endpoint name is Api session event editor attributeaction remove.
Use this endpoint to Remove existing Attribute Action
0 REQUIRED (ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) Attribute Action
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorattributeaction/remove/", options)
