Api session event editor attributeaction add
API Endpoint: editorattributeaction/add.
API Endpoint name is Api session event editor attributeaction add.
Use this endpoint to Add new Attribute Action
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'JavaScript example POST:
body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorattributeaction/add/", options)
