Api session event editor actionmenu add
API Endpoint: editoractionmenu/add.
API Endpoint name is Api session event editor actionmenu add.
API Endpoint to Add new Action Menu
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editoractionmenu/add/", options)
