Api session event editor update
Revision as of 11:19, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: eventeditor/update.
API Endpoint name is Api session event editor update.
API Endpoint to Waits for update of all active Overlay, Indicator, Panel and Trigger. Note: for long-running updates use: set_scheduled_update/ to schedule an update.
0 OPTIONAL (true, false) Reset all X-Queries (optional)
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editor/update/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'
JavaScript example POST:
 body: 'false'
fetch("https://engine.tygron.com/api/session/event/editor/update/", options)
