Api session event editor map set height sector
Revision as of 09:43, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Update Heightmap Sector Data.
API Endpoint name is Api session event editor map set height sector
0 REQUIRED (HEIGHT Integer ID) Height Sector ID
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Header: sector widthPoints, columns, rows, baseX, baseY
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Matrix Data Array
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_sector/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_sector/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript Example POST:
 body: '[ 1, 1, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editormap/set_height_sector/", options)
