Api session event editor map set height geotiff
API Endpoint to Set Height GeoTIFF.
API Endpoint name is Api session event editor map set height geotiff
| 0 | REQUIRED | (GEO_TIFF Integer ID or multiple values in array [1, 2, 3]) | GeoTIFF |
| 200 | Integer (Integer) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript Example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/", options)
