Api session event editor functionoverride reset values
Revision as of 09:41, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Reset Values.
API Endpoint name is Api session event editor functionoverride reset values
0 REQUIRED (FUNCTION Integer ID) Function
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/reset_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/reset_values/", options)
