Api session event editor eventbundle set description
Revision as of 09:41, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set Description.
API Endpoint name is Api session event editor eventbundle set description
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle
1 REQUIRED (String) String
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'
JavaScript Example POST:
 body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/set_description/", options)
