Api session event editor eventbundle add event
Revision as of 09:41, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add Event.
API Endpoint name is Api session event editor eventbundle add event
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle
1 REQUIRED (true, false) Boolean true or false
200 Integer (Integer)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/add_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/add_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript Example POST:
 body: '[ 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/add_event/", options)
