Api session event editor cinematic add keypoint event bundle
API Endpoint to Add Keypoint Event Bundle.
API Endpoint name is Api session event editor cinematic add keypoint event bundle
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (EVENT_BUNDLE Integer ID) | Event Bundle |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_event_bundle/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'JavaScript Example POST:
body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_event_bundle/", options)
