Api session event editor chat send message
API Endpoint to Send Message.
API Endpoint name is Api session event editor chat send message
| 0 | REQUIRED | (Enumeration) | Channel | AI_ASSISTANT or DOMAIN |
| 1 | REQUIRED | (String) | String |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorchat/send_message/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "DOMAIN", "Text" ]'JavaScript Example POST:
body: '[ "DOMAIN", "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/send_message/", options)
