Api session event editor chat reset channel
API Endpoint to Reset Channel.
API Endpoint name is Api session event editor chat reset channel
| 0 | REQUIRED | (Enumeration) | Channel | AI_ASSISTANT or DOMAIN |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorchat/reset_channel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"DOMAIN"'JavaScript Example POST:
body: '"DOMAIN"'
fetch("https://engine.tygron.com/api/session/event/editorchat/reset_channel/", options)
