Api session event editor building set slanting roof height
API Endpoint to Change Height of the Slanting Roof of a Building section.
API Endpoint name is Api session event editor building set slanting roof height
| 0 | REQUIRED | (BUILDING Integer ID) | Building ID | |
| 1 | REQUIRED | (Integer number) | Section ID | |
| 2 | REQUIRED | (Floating point number) | Slanting roof height |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 31 ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 71 ]'JavaScript Example POST:
body: '[ 1, 1, 31 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/", options)
