Api session event editor building generate rotation angles
Revision as of 09:40, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Calculation a rotation angle for Building having the identifying attribute polygons, optionally only for specified Building..
API Endpoint name is Api session event editor building generate rotation angles
0 REQUIRED (String) Identifying attribute
1 REQUIRED (String) Rotation attribute
2 OPTIONAL (BUILDING Integer ID or multiple values in array [1, 2, 3]) Specific BuildingIDs only (optional)
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Identifying attribute", "Rotation attribute", "" ]'
JavaScript Example POST:
 body: '[ "Identifying attribute", "Rotation attribute", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/", options)
