Api session event editor attributeaction duplicate
Revision as of 09:40, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Duplicate existing Attribute Action.
API Endpoint name is Api session event editor attributeaction duplicate
0 REQUIRED (ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) Attribute Action
200 Integer[] (Integer array)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorattributeaction/duplicate/", options)
