Api session event editor area remove group
API Endpoint to Remove Group.
API Endpoint name is Api session event editor area remove group
| 0 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_group/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text 1"'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_group/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text 1", "Text 2", "Text 3" ]'JavaScript Example POST:
body: '"Text 1"'
fetch("https://engine.tygron.com/api/session/event/editorarea/remove_group/", options)
