Api session event editor actionmenu remove actions
API Endpoint to Remove Actions.
API Endpoint name is Api session event editor actionmenu remove actions
| 0 | REQUIRED | (ACTION_MENU Integer ID or multiple values in array [1, 2, 3]) | Action Menu | |
| 1 | REQUIRED | (MapLink or multiple values in array [a, b, c]) | MapLink[] | |
| 2 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Integer[] |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SETTINGS", 1 ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "SETTINGS", "ACTION_MENUS", "ADDRESSES" ], [ 1, 2, 3 ] ]'JavaScript Example POST:
body: '[ 1, "SETTINGS", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/", options)
