Api session event editor set scheduled update
API Endpoint to Schedule a long-running update of all active Overlay, Indicator, Panel and Trigger..
API Endpoint name is Api session event editor set scheduled update
| 0 | OPTIONAL | (Integer number) | Scheduled Time in milliseconds since epoch 1970. Note: use 0 for direct execution or -1 to cancel | |
| 1 | OPTIONAL | (String) | Send Email to this Address when finished (optional) | |
| 2 | OPTIONAL | (String) | Send SMS to this number when finished (optional) |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editor/set_scheduled_update/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 0, "", "" ]'JavaScript Example POST:
body: '[ 0, "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editor/set_scheduled_update/", options)
