Api session event editor update with id
API Endpoint to Waits for update of all active Overlay, Indicator, Panel and Trigger with unique ID. Note: for long-running updates use: set_scheduled_update/ to schedule an update. API Endpoint name is Api session event editor update with id
| 0 | REQUIRED | (true, false) | Reset all X-Queries | true or false |
| 1 | REQUIRED | (Integer number) | Unique Update ID to prevent multiple updates |
| 200 | Boolean (Content was updated) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editor/update_with_id/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ false, 65 ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editor/update_with_id/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ true, 74 ]'JavaScript Example POST:
body: '[ false, 65 ]'
fetch("https://engine.tygron.com/api/session/event/editor/update_with_id/", options)
