Api session event editor zoning remove
Revision as of 09:13, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Remove existing Zoning
0 REQUIRED (ZONE Integer ID or multiple values in array [1, 2, 3]) Zone
1 REQUIRED (true, false) Remove Children true or false
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorzoning/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorzoning/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], false ]'
JavaScript Example POST:
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/remove/", options)
