Api session event editor time set start date
Revision as of 09:12, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set Start Date
0 REQUIRED (Integer number) Long
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '73'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '57'
JavaScript Example POST:
 body: '73'
fetch("https://engine.tygron.com/api/session/event/editortime/set_start_date/", options)
