Api session event editor stakeholder add
API Endpoint to Add new Stakeholder
| 200 | Integer (Integer) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'JavaScript Example POST:
body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/add/", options)
