Api session event editor overlay set service source
API Endpoint to Set the Service Source for a specified Service Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID) | Service Overlay ID | |
| 1 | REQUIRED | (SOURCE Integer ID) | Source ID |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript Example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_service_source/", options)
