Api session event editor overlay set legend entry value
Revision as of 09:09, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Change the value of a specified legend entry of a custom legend of a specified Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (true, false) Affect the custom difference legend (false means affect the normal custom legend) true or false
2 REQUIRED (Integer number) ID of entry which should be changed
3 REQUIRED (Floating point number) New value for the entry
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_legend_entry_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false, 1, 52 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_legend_entry_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false, 1, 55 ]'
JavaScript Example POST:
 body: '[ 1, false, 1, 52 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_legend_entry_value/", options)
