Api session event editor overlay set combo formula
Revision as of 09:09, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set formula for a Combo Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (String) Formula
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_combo_formula/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Formula" ]'
JavaScript Example POST:
 body: '[ 1, "Formula" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_combo_formula/", options)
