Api session event editor overlay remove overlay function
API Endpoint to Remove a specified Function to highlight from a specified FUNCTION_HIGHLIGHT Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to a FUNCTION_HIGHLIGHT Overlay) | |
| 1 | REQUIRED | (FUNCTION Integer ID or multiple values in array [1, 2, 3]) | Function IDs |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_overlay_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_overlay_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'JavaScript Example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_overlay_function/", options)
