Api session event editor neuralnetwork set neural network
API Endpoint to Set Neural Network
| 0 | REQUIRED | (NEURAL_NETWORK Integer ID) | Neural Network | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | byte[] | |
| 2 | REQUIRED | (String) | String |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Text" ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], "Text" ]'JavaScript Example POST:
body: '[ 1, 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/", options)
