Api session event editor neuralnetwork export
API Endpoint to Export
| 0 | REQUIRED | (NEURAL_NETWORK Integer ID) | Neural Network |
| 200 | byte[] (byte array) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript Example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorneuralnetwork/export/", options)
