Api session event editor netcluster set scenario
Revision as of 09:07, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set Scenario
0 REQUIRED (NET_CLUSTER Integer ID) Net Cluster
1 REQUIRED (SCENARIO Integer ID) Scenario
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetcluster/set_scenario/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/set_scenario/", options)
