Api session event editor netcluster set fraction connected
API Endpoint to Set Fraction Connected
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster | |
| 1 | OPTIONAL | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetcluster/set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "" ]'JavaScript Example POST:
body: '[ 1, "" ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/set_fraction_connected/", options)
