Api session event editor measure remove upgrade
Revision as of 09:07, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Remove specified Upgrade Spatials from a Measure.
0 REQUIRED (MEASURE Integer ID) Measure IDs
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Upgrade Spatial IDs
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_upgrade/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_upgrade/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/remove_upgrade/", options)
