Api session event editor measure add building
API Endpoint to Add a new Building to specified Measure
| 0 | REQUIRED | (MEASURE Integer ID or multiple values in array [1, 2, 3]) | Measure IDs |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript Example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_building/", options)
