Api session event editor map set height overlay
Revision as of 09:06, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Update Elevation Model from Grid Overlay
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 OPTIONAL (Integer number) Timeframe (optional)
200 Integer (Amount of sectors updated)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 0 ]'
JavaScript Example POST:
 body: '[ 1, 0 ]'
fetch("https://engine.tygron.com/api/session/event/editormap/set_height_overlay/", options)
