Api session event editor customgeometry add
API Endpoint to Add a Custom Geometry to render.
| 0 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | 3D Data array | |
| 1 | REQUIRED | (TColor or multiple values in array [a, b, c]) | Color | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Texture Names | |
| 3 | REQUIRED | (boolean or multiple values in array [a, b, c]) | Use absolute height from 3D Data array | |
| 4 | REQUIRED | (boolean or multiple values in array [a, b, c]) | Render both the front and back face |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorcustomgeometry/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1.0, 2.0 ], -65536, "Texture Name 1", true, true ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorcustomgeometry/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], [ -65536, -16744448, -16776961 ], [ "Texture Name 1", "Texture Name 2", "Texture Name 3" ], [ true, false, true ], [ true, false, true ] ]'JavaScript Example POST:
body: '[ [ 1.0, 2.0 ], -65536, "Texture Name 1", true, true ]'
fetch("https://engine.tygron.com/api/session/event/editorcustomgeometry/add/", options)
