Api session event editor building add standard
Revision as of 09:03, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add Standard
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
200 Integer (Integer)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_standard/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_standard/", options)
