Api session event editor building add road
API Endpoint to Add Road
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 200 | Integer (Integer) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_road/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript Example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_road/", options)
