Api session event editor update
API Endpoint to Waits for update of all active Overlay, Indicator, Panel and Trigger. Note: for long-running updates use: set_scheduled_update/ to schedule an update.
| 0 | OPTIONAL | (true, false) | Reset all X-Queries (optional) |
| 200 | Boolean (Content was updated) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editor/update/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'JavaScript Example POST:
body: 'false'
fetch("https://engine.tygron.com/api/session/event/editor/update/", options)
