Api session event editor set scheduled update
Revision as of 09:01, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Schedule a long-running update of all active Overlay, Indicator, Panel and Trigger.
0 OPTIONAL (Integer number) Scheduled Time in milliseconds since epoch 1970. Note: use 0 for direct execution or -1 to cancel
1 OPTIONAL (String) Send Email to this Address when finished (optional)
2 OPTIONAL (String) Send SMS to this number when finished (optional)
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editor/set_scheduled_update/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 0, "", "" ]'
JavaScript Example POST:
 body: '[ 0, "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editor/set_scheduled_update/", options)
