Api session event editor eventbundle remove
Revision as of 08:58, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Remove existing Event Bundle
0 REQUIRED (EVENT_BUNDLE Integer ID or multiple values in array [1, 2, 3]) Event Bundle
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/remove/", options)
