Api session event editor cinematic add keypoint event bundle
Revision as of 08:58, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Add Keypoint Event Bundle
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic
1 REQUIRED (Integer number) Integer
2 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_event_bundle/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
JavaScript Example POST:
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_event_bundle/", options)
