Api session event editor chat send message
Revision as of 08:58, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Send Message
0 REQUIRED (Enumeration) Channel AI_ASSISTANT or DOMAIN
1 REQUIRED (String) String
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorchat/send_message/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "DOMAIN", "Text" ]'
JavaScript Example POST:
 body: '[ "DOMAIN", "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/send_message/", options)
