Api session event editor chat reset channel
Revision as of 08:58, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Reset Channel
0 REQUIRED (Enumeration) Channel AI_ASSISTANT or DOMAIN
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorchat/reset_channel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"DOMAIN"'
JavaScript Example POST:
 body: '"DOMAIN"'
fetch("https://engine.tygron.com/api/session/event/editorchat/reset_channel/", options)
