Api session event editor building set floors
Revision as of 08:57, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Change amount of floors
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building ID
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Section ID
2 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Number of floors
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_floors/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_floors/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_floors/", options)
