Api session event editor building set decals
Revision as of 08:57, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Set Decals
0 REQUIRED (BUILDING Integer ID) Building
1 REQUIRED (Enumeration) FaceType BASEMENT, EXTRA, GROUND, ROOF or TOP
2 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) float[]
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_decals/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "BASEMENT", "" ]'
JavaScript Example POST:
 body: '[ 1, "BASEMENT", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_decals/", options)
