Api session event editor building add geometry
API endpoint to Add a custom Building geometry
| 0 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building ID | |
| 1 | REQUIRED | (CUSTOM_GEOMETRIE Integer ID or multiple values in array [1, 2, 3]) | Custom Geometry ID | |
| 2 | REQUIRED | (boolean or multiple values in array [a, b, c]) | Primary Building for geometry | |
| 204 | No Content |
Curl Example POST:
curl=API_TOKENCurl Example multi item POST:
curl=API_TOKEN
