Api session event editor building set attribute
Revision as of 08:53, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Set Building attribute value
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values
200 Boolean (Content was updated)
Curl Example POST:
curl=API_TOKEN
Curl Example multi item POST:
curl=API_TOKEN
